Car paints for Standard Surface and OpenPBR are vastly different presets. Why?
ssjenforcer191191191
I decided to try the standard surface again after updating my Arnold version.
I made a car paint material and made it white.  However, it looked quite greyish in the IPR.
I did the same thing with an OpenPBR material, and it looked white like it should.
I realized that the preset for Standard Surface gives base weight 0.5 instead of the OpenPBR.
Which one is 'accurate'?  I don't see why they should be so vastly different.  It obviously looks white only if I use base weight of 1.0.
The same goes for the two tone paint, which offers a 0.8 to 1.0 comparison.
Why is the preset so obscure for Standard Surface?
lee_griggs
They are there just as a guide. If you want a realistic car paint material, then use the Car Paint shader.
Lee Griggs
Arnold rendering specialist
AUTODESK
I see.  Thanks.
I had forgotten after getting so used to inserting nodes.
Even with a 0.8 base weight, the car paint shader material still retains the white colour look.
