Arnold for Cinema 4D Forum
Rendering with Arnold in CINEMA 4D using the C4DtoA plug-in.
Can't use Cd attribute from Houdini in Cinema4D Arnold
4 REPLIES 4
samghoreyshi
207 Views, 4 Replies
Hello everyone,
I was trying to render my object inside Cinema4D with Arnold but I don't know why attribute Cd doesn't work. How can I fix this?
Thank you
Tags (1)
Labels (1)
4 REPLIES 4
Is the Cd attribute even there? Check the Geometry Spreadsheet in Houdini.
If you export to ASS instead of ABC, is it in there?
// Stephen Blair
// Arnold Renderer Support
Yes I checked that, attribute Cd is there, I also tested the object in blender, cycles can read attribute Cd.
I don't have Arnold for Houdini so I don't have access to .Ass file and Arnold properties inside Houdini, there's no way to do this with .ABC file ?
If you load the Alembic file via the native loader, then the attributes are added as vertex maps. Use the vertex map shader to read them (or try vmap_Cd in the user data shader).
Alternatively you can use the Arnold Procedural node instead, which reads the attributes are user parameters, and you can use the user_data shader as in your screenshot. This method has the advantage of loading the geometry in render-time, and keeps your scene light.
https://docs.arnoldrenderer.com/display/A5AFCUG/Alembic
// Peter Horvath
// C4DtoA developer
Loading geometry with Arnold procedural node worked perfectly, thank you so much.
