Can't connect Shader to Ray Switch
lizGYM66
lizGYM66
Quite possible I'm doing something wrong but I can't connect a standard surface shader to any input on the ray_switch shader. The screenshot doesn't show the no entry logo when hovering over the ray_switch shader.
lee_griggs
I just see rayswitch_rgb (colors per ray) in your screenshot. You should use the rayswitch shader for connecting and adjusting shaders instead of colors.
Lee Griggs
Arnold rendering specialist
AUTODESK
lizGYM66
Thanks @lee_griggs  - I totally spaced as in Redshift there is only a single ray switch shader rather than the two options in Arnold. My bad.
