Arnold for Cinema 4D Forum
Rendering with Arnold in CINEMA 4D using the C4DtoA plug-in.
Can Shadow Matte AOVs be achieved on a per-light basis? Or even by Light Group?
11 REPLIES 11
Message 1 of 12
chadGE3G6
833 Views, 11 Replies
Tags (3)
Labels (3)
11 REPLIES 11
Message 2 of 12
Stephen.Blair
in reply to: chadGE3G6
No, you can't do that with current shadow matte shader. We need to implement a version of the shader that uses closures, so that then you can use LPEs with it.
// Stephen Blair
// Arnold Renderer Support
Message 3 of 12
chadGE3G6
That would be fantastic and powerful. Thanks!
Message 4 of 12
Is this still true for version 5.1.0.1 ?
Thank you,
Message 5 of 12
Stephen.Blair
@Jim Polk As of Arnold 5.1, you can get the shadow matte for a specific light.
Per-lightgroup shadow mattes: The shadow_matte shader has a new aov_group parameter that when enabled makes the shader sensitive only to lights with a matching aov setting.
In MtoA, shadow matte has a Light Group box that restricts the shadow matte to a single light.
// Stephen Blair
Message 6 of 12
hitecom8172
so lpe's are theoretically possible.
Message 7 of 12
Stephen.Blair
in reply to: hitecom8172
No, that's not done with LPEs
// Stephen Blair
Message 8 of 12
in reply to: Stephen.Blair
Hi Stephen, Apologies for my late reply,..
We only use Maya for modelling not for lighting or lookdev..
We use Crom, an in-house program that's like Katana,etc., and create our own assfiles
using the Arnold Python API. Would you be so kind as to re-express your answer in
those terms?
Thank you very much,
Jim
Message 9 of 12
Just to add...if you have any actual assfiles that show how things are connected that would especially helpful. Ty!
Message 10 of 12
Just to add..
In Arnold 4, we created an EXR composed of what we call 'castshad' layers, one for each light in the scene.
Each of these layers shows *all* of the shadows for *all* objects for *that* light.
The geometry objects are assigned a grey shader, in A5 it's something like:
standard_surface
name TrackManGeom
base 1
base_color 0.5 0.5 0.5
Each light's block in the assfile fills the 'aov' param with something like 'key1Light',etc.
From your earlier answer, I understand that the shadow_matte block should be configured like:
shadow_matte
name thisMatte
aov_group 'key1Light'
But what I'm not getting is the relationship between the standard_surface block and the shadow_matte block.
Thank you,
Message 11 of 12
Stephen.Blair
@Jim Polk
You just have to set the shadow_matte.aov_group parameter with a string value that matches the shadow-matte-aov-group-test.ass parameter of one or more lights.
An example ass file is attached.
// Stephen Blair
Message 12 of 12
Awesome! I'll study this, Thank you!!
Technology Administrators
