Arnold for Cinema 4D Forum
Rendering with Arnold in CINEMA 4D using the C4DtoA plug-in.
C4toA 2.3.0.1 and cryptomatte crash C4D
9 REPLIES 9
Message 1 of 10
edenexposito
473 Views, 9 Replies
Seems that latests version of C4toA crash C4D when try to add cryptomatte to scene.
Maybe need's a new version of cryptomatte to work properly? it's a bug?
Tags (1)
Labels (1)
9 REPLIES 9
Message 2 of 10
The node names have changed in the 2.3.0 release, for instance we don't use the 'c4d|' prefix any more. Therefore the cryptomatte shader does not recognize the name coming from C4DtoA, which might explain the crash. (I have no crash in my simple test scene though.) I think a new build is coming supporting the new naming, but Jonah can confirm.
Message 3 of 10
A new version is coming very soon where the new style of the names is processed much like the old ones. The crash (at least the one I know about) happens when you have non-AOV shaders in your scene as well, like shadow matte or utility, and this has also been fixed.
Message 4 of 10
edenexposito
in reply to: edenexposito
@Jonah Friedman Latest version (beta 3) seems works properly now. Thanks
Message 5 of 10
HI
I'm getting this error in Maya for the latest Cryptomatte (beta3)
00:00:00 746MB WARNING | unable to load dynamic library C:/Arnold_Shader/Cryptomatte/bin\cryptomatte.dll: The specified module could not be found.
any solutions?
Message 6 of 10
Stephen.Blair
This is the same crash? If not, can you ask a new question please?
// Stephen Blair
// Arnold Renderer Support
Message 7 of 10
tested the new Cryptomatte_2.0.0b3-ai5.1.0.1
c4D : worked fine
Maya 2018 Update 2: not working (00:00:00 746MB WARNING | unable to load dynamic library C:/Arnold_Shader/Cryptomatte/bin\cryptomatte.dll: The specified module could not be found)
Houdini 16.5.439: not showing at all
Message 8 of 10
Stephen.Blair
I have an answer. Ask a new question so I can respond.
// Stephen Blair
Message 9 of 10
I highly recommend re-downloading Beta 3, especially if you're on Windows. There was an issue with the build which is now resolved (which also is likely the cause of @rachid Hadj Abderrahmane's issues).
Message 10 of 10
Thank you @Jonah , re-downloading the file fixe the issue
