Arnold for Cinema 4D Forum
Rendering with Arnold in CINEMA 4D using the C4DtoA plug-in.
C4DtoA - Using Mesh Particles with Bend Deformers
8 REPLIES 8
Message 1 of 9
662 Views, 8 Replies
My problem is simple, I have a plane which I'm using an Arnold Mesh Particles on to render a custom object, and I need to animate and reposition the plane with a C4D bend deformer. When I use it all the mesh particles render in twisted way facing upwards.
How could I have the mesh particles follow the UV of the plane??
Tags (2)
Labels (2)
8 REPLIES 8
Message 2 of 9
Stephen.Blair
Check the Channels tab of the Mesh Particles tag.
Set the Rotation to Normal
// Stephen Blair
// Arnold Renderer Support
Message 3 of 9
I actually did that and my machine had frozen up... I'm going to use a smaller plane to simulate this on.
Do you think @Stephen Blair then I could create a arnold .ass file of a smaller portion of what I'm using and clone that .ass file to the surface of a plane?
Message 4 of 9
Ok, so it worked flat but as I use a c4d deformer bend tool c4d freezes up. It seems that it as re-angled the object being cloned using the c4dtoa "Arnold Mesh Particles".
Message 5 of 9
Stephen.Blair
Just how big is the plane? The custom object is being instanced in Arnold, so the complexity of that object shouldn't matter, at least not for rendering.
// Stephen Blair
Message 6 of 9
Stephen.Blair
This is with the Arnold IPR window open?
// Stephen Blair
Message 7 of 9
@Stephen Blair
Ok so I've made it back to the office today after the holiday. My plane size is 1.267 inches wide by 600 inches long. I have it kinda heavily subdivided so I'm able to render the mesh object to "Shape mode = Sequential" so that all the custom shapes are rendered aligned to the vertices of the plane. And the plane is a not being subdivided by an effector or subdivision surface object it's an editable object now.
Message 8 of 9
peter.horvath6V6K3
The Bend deformer does not alter the number of vertices so it should not make any difference in the performance. Is C4D frozen for a couple of seconds (minutes?) or completely? Is it the IPR or the PV render too?
Message 9 of 9
Yeah, so it freezes for about 5 to 20 minutes in when I start up the IPR. I'm clearing out my file and just working with a segment of the plan and then going to try to use a spline wrap to clone that segment onto. That segment has the Arnold mesh particles applied to it to render the object to the verticies.
Technology Administrators
