Arnold for Cinema 4D Forum
Rendering with Arnold in CINEMA 4D using the C4DtoA plug-in.
C4DtoA + TurbulenceFD Console Error
4 REPLIES 4
759 Views, 4 Replies
I get the following error message! Any Idea??
C4DtoA | 00:00:00 759MB ERROR| [c4dtoa] Could not find TFD plugin library
C4DtoA | 00:00:00 761MB ERROR| [tfd] Failed to load TFD shared library from
C4DtoA | 00:00:00 762MB WARNING| [volume] /TurbulenceFD_Container: Could not create volume with plugin volume_tfd
4 REPLIES 4
peter.horvath6V6K3
If you have this error in R20 using C4DtoA 2.4.1 or 2.4.1.1 then please update to 2.4.1.2 which contains a fix. Otherwise please tell me your C4D, C4DtoA and TFD version.
Just saw it in the release notes. Thank you a lot!
Bishal_Kar
Hi, my TFD version is v1.0 Rev 1449 2019-09-17 and my C4dtoA version is 2.5.2.. Still I am having the same problem "could not create volume with plugin volume_tfd. Please give me a perfect solution of this. Thanks!
Can you show me the full log please? Is there anything else in there which gives us a clue why the volume is not generated?
There was an API change in recent TFD versions, which broke older C4DtoA versions. It was fixed in C4DtoA 2.6.1.4, so could you try the latest version if it works?
Technology Administrators
