Arnold for Cinema 4D Forum
Rendering with Arnold in CINEMA 4D using the C4DtoA plug-in.
C4DtoA Skin Shader
5 REPLIES 5
ali_said
338 Views, 5 Replies
C4DtoA Skin Shader
Hi! I'm having trouble finding any up-to-date tutorials on C4DtoA skin shader. Specifically, I am trying to create a hyper realistic look on a human model but there are no tutorials on how to properly do this. Even the C4DtoA documentation is out of date and does not show how to accomplish this. I am trying to get results similar to this: https://www.youtube.com/watch?time_continue=1582&v=5z68h2GmmlM&feature=emb_title
Any help would be very much appreciated!
Tags (1)
Labels (1)
5 REPLIES 5
in reply to: ali_said
lee_griggs
More here (MtoA, but the shader is the same).
A lot of the examples here use skin. What in the documentation is "out of date"?
Lee Griggs
Arnold rendering specialist
AUTODESK
ali_said
in reply to: lee_griggs
Thank you for the help, Lee. I really like your work. I've run into several cases where there were slight discrepancies between the options shown on my C4DtoA (R20) and the C4DtoA documentation; One example can be seen here in displacement: https://docs.arnoldrenderer.com/display/A5AFCUG/Rendering+Displacement+Maps+from+C4D
"vector_displacement" is not an available node so I was considering discrepancies like this to be "out of date". Perhaps I've installed Arnold into C4D incorrectly or my build is out of date.
ali_said
Thank you!
Right, it is indeed out of date. Normal and vector displacement shaders are now merged into one displacement shader with a combo box to select the type. We're going to update the docs, thanks.
