Arnold for Cinema 4D Forum
Rendering with Arnold in CINEMA 4D using the C4DtoA plug-in.
C4DtoA plugin not showing
8 REPLIES 8
Message 1 of 9
1935 Views, 8 Replies
Hi all, new here. Running Cinema 4D R19.068 on iMac Pro OS X 10.13.6. Downloaded the trial plugin. Installer goes smoothly but plugin not showing in C4D. Do I need to install the RLM even for the trial?
Tags (2)
Labels (2)
8 REPLIES 8
Message 2 of 9
Stephen.Blair
No, you don't need RLM. 1) The plugin is unlicensed, and 2) the license does one thing only: remove the watermark from Arnold renders.
Where did C4DtoA install? I've seen customers with CINEMA 4D folders in /Applications in in the user folder, and sometimes C4DtoA is not in the right place.
// Stephen Blair
// Arnold Renderer Support
Message 3 of 9
in reply to: Stephen.Blair
Thanks for the quick reply. It's in the default: /Applications/Maxon/ - same as previous versions. Isn't that correct?
Message 4 of 9
Stephen.Blair
So both CINEMA 4D and C4DtoA are in /Applications/MAXON/CINEMA 4D R19 ?
Is there an "arnold/bin" folder there too?
Does this machine have processors that support SSE4.1 ?
https://arnoldsupport.com/2016/10/08/arnold-mtoa-how-to-check-if-your-processor-supports-sse4-1/
Can you start CINEMA 4D or commandline in a Terminal, and post everything that is printed out (probably best to post it as an attachment)?
// Stephen Blair
Message 5 of 9
So I have Cinema 4D R19 with an /Arnold folder in it, but also /plugins/C4DtoA. See screenshots
Message 6 of 9
But I see in CGTalk others have used iMac Pro with C4dtoA
Message 7 of 9
peter.horvath6V6K3
Is it the folder where your application is installed? I don't see any files or folders which belong to C4D, e.g. executables, etc.
Message 8 of 9
Stephen.Blair
There is no CINEMA 4D in that folder. You must have CINEMA 4D installed somewhere else.
// Stephen Blair
Message 9 of 9
Yes, it seemed to be in 2 places - I chose the wrong one. Thanks for your help.
Technology Administrators
