Arnold for Cinema 4D Forum
Rendering with Arnold in CINEMA 4D using the C4DtoA plug-in.
C4DtoA not rendering Hair Instances?
2 REPLIES 2
544 Views, 2 Replies
I have set up a scene where I use Cinema's hair system to clone a bunch of objects via instance on a plane's surface. With the Standard renderer everything renders normally, but when I use the Arnold renderer the hair instances are rendered as black boxes. Is this just a bug/ missing code or can I do something about this? I have the "render hair" option unchecked already so this can not be the problem.
Best regards,
Fynn
Tags (2)
Labels (2)
2 REPLIES 2
Stephen.Blair
That's not supported
// Stephen Blair
// Arnold Renderer Support
Put the Hair object inside a Connector, it should render fine that way 🙂
Technology Administrators
