Arnold for Cinema 4D Forum
Rendering with Arnold in CINEMA 4D using the C4DtoA plug-in.
C4DtoA Network install - IPR Slowness
6 REPLIES 6
boeinghoff
243 Views, 6 Replies
Hey Guys,
we are currently changing our c4d pipeline, so cinema is loading an c4dtoa version from the network on startup. Everything works fine, execept the IPR start performance. If c4dtoa is installed locally, it starts immediately to render. With the network version it's loading the needed data from the network (20 sec) and after stopping and restarting the IPR session it's loading the plugin data again form the network.
From Houdini, Maya and Softimage I'm used to a long software load time on startup, but than it's fast. With Cinema it's the opposite, it starts really fast, but loads the plugin data when it's needed.
Is there a way to force Cinema to keep the PluginData in Memory for the session?
Andy
Ps:
I asked Steve this also yesterday on his blog.
https://arnoldsupport.com/2016/02/04/c4dtoa-installing-c4dtoa-in-a-custom-location/comment-page-1/?u...
6 REPLIES 6
My first question would be, is that really Cinema which is causing the delay? For instance do you experience the same delay with other plugins, or when starting a render to the Picture Viewer? Can you check the Arnold log (go to Render settings > Diagnostics and set the log level to Debug)?
When the Arnold render session starts, it loads plugins and meta data files from the C4DtoA folder, maybe those are causing the delay.
boeinghoff
in reply to: boeinghoff
I'm sure that the loading of plugins and meta data causes the delay. See the txt files. Is it normal that it takes that long to load the stuff? Like I said, I haven't noticed this delays in Houdini/Maya/Softimage, while we are using the same network plugin workflow for this tools.
Is there a workaround, that speeds up the startup speed?
debug-network.txtdebug-local.txt
Stephen.Blair
We need a Debug-level log. The 20s happen where the licensing happens.
// Stephen Blair
// Arnold Renderer Support
Yeah it seems the plugins were loaded fine:
loaded 2 plugins from 2 lib(s) in 0:00.01
Looks more like licensing as Stephen said.
boeinghoff
Oh Guys,
you are so right. Our Applauncher-System writes two license files into the cinema_launch.bat
set solidangle_LICENSE=1081@licsrv
set ADSKFLEX_LICENSE_FILE=27000@licsrv
The old solidangle_LICENSE line caused the delay...
Thanks, and sorry for the noise!
Andy
No worries, I'm glad you have found the problem.
