C4DTOA: low resolution with substance assets
I'm trying to render out a substance asset (https://source.allegorithmic.com/#/substances/category/Ground/cc40196857130cd5367a5d248bb5789a796dfc3b) however it's coming out in very low resolution. I used C4DTOA convert substance asset to arnold material feature to create the shader. Before I converted I set the asset resolution to 2048x2048 however in IPR it still comes out in low resolution.
Where could be the problem? Heres a screenshot of the node graph.
http://i.imgur.com/TTu9qjp.jpg
Thanks!
peter.horvath6V6K3
That should be it. The textures are generated according the settings in the Substance Asset while exporting the scene to Arnold. You can check them in the tex/substance_cache folder of your project.
