C4dtoA instance issue
albert.adler
albert.adler
Why its not possible to render an instance of an instance in C4dtoA? Different instance mode doesn't change anything. Standard render in Cinema4d works fine (right rendering).
When using Cinema4D R20 import for CAD files null objects and instances are automatically created like this.
How to fix it?
Arnold version: 2.4.2.1
Thank you in advance.
Albert
Stephen.Blair
C4DtoA doesn't seem to support that yet. It instances the object under the null, but doesn't create a second instance to match.
A possible quick-and-dirty workaround: stick a MoInstancer under the null. The MoInstance doesn't have to reference any object, but putting it there forces C4DtoA to create a new copy of the cube and then instance it.
So you do get the overhead of another object, but that object does get instanced. That worked at least in my simple test scene.
// Stephen Blair
// Arnold Renderer Support
peter.horvath6V6K3
Could you please check this fix and let me know if it works properly?
https://safeshare.solidangle.com/index.php/s/pTZUcZQ90TUbyOJ
password: kkuMHA7j
albert.adler
Hello Peter, Thanks for your help.
I've send you an E-Mail regarding this topic.
peter.horvath6V6K3
This issue should be fixed in C4DtoA 2.4.5.
Marcus_Schneider
Thank you Peter.
