Arnold for Cinema 4D Forum
Rendering with Arnold in CINEMA 4D using the C4DtoA plug-in.
C4DtoA HDRI Blur
2 REPLIES 2
abodal
1081 Views, 2 Replies
C4DtoA HDRI Blur
Is it possible to blur an HDRI in C4DtoA?
For example, if I have a highly reflective surface (let's say chrome), and am lighting my scene with an HDRI, it would be nice to be able to use a specific HDRI for lighting but blurring it so that a perfect mirror image of the HDRI doesn't appear in my reflective surface.
Obviously I could just make a copy of the HDRI texture and blur it in Photoshop, but I'm wondering if there is a way to do this directly in C4DtoA/with Arnold in general.
Tags (3)
Labels (3)
2 REPLIES 2
lee_griggs
in reply to: abodal
You could lower the Resolution of the Skydome light, but it probably wouldn't look very good closeup.
Adding Specular Roughness would be a more physically accurate way to do it.
Lee Griggs
Arnold rendering specialist
AUTODESK
abodal
in reply to: abodal
Thanks for the tip, I'll try it out.
Also wasn't exactly sure what you mean by adding specular roughness. Do you mean to the texture (hdri for example)?
**EDIT**
Haha nevermind, assuming you meant adding it to the reflective material. The answer was so obvious it was hiding in plain sight 😛
Thanks again!
