Hi! What is the workflow to use the dicing camera adaptive subdivision?
Thanks!
Thanks!
I have attached a test scene. You have to set the camera to the Render Settings > Subdivision > Dicing camera and also set the Subdivision > Adaptive error in the Arnold tag on the object.
We're going to add more info to the documentation.
Also note that the IPR does not update properly at the moment when you move the dicing camera. You have to stop and restart to see the difference. It will be fixed in a future release.
Amazing! Thanks @Peter Horvath
@Laamchuen Lee Should be the same workflow in Maya, set the dicing camera in the render settings and setup the subdivision on the shape.
