Arnold for Cinema 4D Forum
Rendering with Arnold in CINEMA 4D using the C4DtoA plug-in.
C4DtoA AOV names
1 REPLY 1
323 Views, 1 Reply
C4DtoA AOV names
hello, i'm following a tutorial which needs the use of the AOV Names tab in the standard shader attributes, the problem is that in C4DTOA 2.0, this option has been removed, I assume there is another worflow to be able to render a separate pass for let's say the direct diffuse of a specific object, but I can't figure out what it is.
Labels (3)
1 REPLY 1
lee_griggs
There are Light Path Expressions. However, you would need to update your plugin to use them.
Lee Griggs
Arnold rendering specialist
AUTODESK
