Arnold for Cinema 4D Forum
Rendering with Arnold in CINEMA 4D using the C4DtoA plug-in.
C4DtoA 2.6.1.2 for Cinema 4D R21 will not work on processors without AVX
6 REPLIES 6
655 Views, 6 Replies
6 REPLIES 6
The Maxon developer forum mentions:
By default, the MSVC build settings of the Cinema 4D R21 SDK activate Advanced Vector Extensions.
This can cause issues on client systems that do not support AVX (the plugin will not show up for them).
The AVX settings are defined in the frameworks\settings\Base.props file.
To disable AVX support, simply remove the line <EnableEnhancedInstructionSet>AdvancedVectorExtensions</EnableEnhancedInstructionSet>
Can we expect an updated Arnold build for R21 which has not the
AVX dependency ?
Best regards
Kurt
Stephen.Blair
What processor do you have ? Does it support SSE 4.1 but not AVX ?
// Stephen Blair
// Arnold Renderer Support
Hi Stephen,
the processor is a Intel Xeon X5670 from a HP Z600.
The processor supports:
MMX,SSE,SSE2,SSE3,SSE4.1,SSE4.2,EM64T,VT-x,AES
The issue is AVX related because when I use the Intel SDE processor emulator where I can emulate AVX features the plugin is loading (but you can't work due to emulated performance).
Kurt
peter.horvath6V6K3
You can expect a new build in the next days, thanks for reporting the issue.
peter.horvath6V6K3
C4DtoA 2.6.1.3 is release with the fix.
Wow, that was very fast.
I just tested the new build and everything is working.
Thank you so much
Kurt
