C4D Team Render Queue
duncan417
duncan417
Does Arnold support C4D's team render via the render queue? Every time I try it fails and crashes just after the client machine has downloaded the assets... the same scene will successfully team render to the picture viewer though
Stephen.Blair
Yes, TeamRender with the render queue is supported.
What crashes? The render? If so, can you get an Arnold log from the TeamRender client?
// Stephen Blair
// Arnold Renderer Support
duncan417
It crashes when the render gets to 5% - the point at which if I am just using team render to picture viewer the "buckets" start to fill in with the image. The console output for the client and host machine appears to be the same, with the last few lines being...
C4DtoA | 00:00:41  6509MB         | starting 16 bucket workers of size 64x64 ...
C4DtoA | 00:00:41  6510MB         |  [skydome_light] /Arnold_Sky: 1000x1000 importance map done in 0:00.04, average energy 0.054939
C4DtoA | 00:04:12  6532MB         |    0% done - 201393 rays/pixel
C4DtoA | 00:04:40  6532MB         |    5% done - 2382 rays/pixel
C4DtoA | 00:04:40  6532MB         | render done in 3:59.072
C4DtoA | 00:05:03  6532MB    ERROR| [c4dtoa] Failed to send data 1037606 to Team Render Server: 1002
C4DtoA | 00:05:03  6532MB         |
C4DtoA | 00:05:03  6532MB         | releasing resources
C4DtoA | 00:00:00  6531MB         | Arnold shutdown
peter.horvath6V6K3
I could not reproduce it so far. Would it be possible to share the scene with me? Can you maybe reproduce it in a simple scene or without the texture? Do you have auto tx enabled in the render settings (Main > Textures > Auto convert textures to tx)? If so can you try replacing the original textures with the tx ones in the scene?
