Arnold for Cinema 4D Forum
Rendering with Arnold in CINEMA 4D using the C4DtoA plug-in.
C4D freezes after adding ctrl-dragging "Ramp_RGB"
6 REPLIES 6
ulrichGTAV3
167 Views, 6 Replies
Hey,
here is an example file:
https://drive.google.com/file/d/1ZIAd6jQsieSjt_oyUQC0HvuKHPDosDyV/view?usp=sharing
I am on C4D  26.107 and C4DtoA 4.2.4 on Windows 10. I have no other plugins in C4D (exept cTools).
But my problem already appeared one or two minor versions before that.
My problem is: when I try to add a ramp_RGB to my node material (either by double clicking in the node area or by ctrl-drag an existing one) than C4D freezes and I have to task manage kill C4D.
Can you see what the reason could be?
Thank you very much...
6 REPLIES 6
ulrichGTAV3
in reply to: ulrichGTAV3
Just tried a completely new file with a new material. Same problem...
ulrichGTAV3
could it be that it is depending on my C4D layout?
if you have two monitors, mybe you could try with this:
peter_horvath
I can reproduce it using your layout. Not sure yet what's the problem, will take a look and let you know.
// Peter Horvath
// C4DtoA developer
ulrichGTAV3
in reply to: peter_horvath
Awesome. But for now i can work with the default nodes layout. So no priority. Mybe I try to recreate my layout tomorrow an see if the problem persists.
In fact, now that I think of it, it could have started when I added those script-buttons near the top right in my layout.
Will let you know if I find something...
Cheers and thx a lot!
peter_horvath
The hang seems to be caused by the docked Attribute Editor and Task Manager in that position in the layout. If I remove any of them, there's no hang. Can you confirm that? It's pretty odd, I have a feeling that it's a bug in C4D. Also I could not reproduce it in R25, so it seems like an R26 specific issue.
// Peter Horvath
// C4DtoA developer
ulrichGTAV3
Yes! Just closing the Task Manager resolves the issue... Now I can add or control-drag as many ramp_RGB nodes as I want...
