Arnold for Cinema 4D Forum
Rendering with Arnold in CINEMA 4D using the C4DtoA plug-in.
C4D Arnold tag
8 REPLIES 8
Message 1 of 9
481 Views, 8 Replies
C4D Arnold tag
You cannot invert normals except if double-sided is unchecked...why?
8 REPLIES 8
Message 2 of 9
peter.horvath6V6K3
Normals facing inwards or outwards affect the render only in single-sided mode. When the object is double-sided is does not matter, both sides are rendered.
Message 3 of 9
in reply to: peter.horvath6V6K3
A sub-surface object?
Message 4 of 9
Well, I'm not sure what's the problem exactly, so if you can send me a scene, that'd be nice.
Message 5 of 9
normals are inverted so sss doesn't render well and I don't want to uncheck double-sided cuz the object is not single-sided. the reason im not using c4d inbuilt reverse normals is because its a simulation and I can't make it editable I only made a test scene editable so you can see the problem.
Message 6 of 9
Interesting use case and indeed inverting normals makes sense here while the mesh is double-sided. I'm going to fix this in the next release. Thanks.
Message 7 of 9
Thanks and your welcome.
Message 8 of 9
peter.horvath6V6K3
Fixed in C4DtoA 2.6.1.5.
Message 9 of 9
Thanks.....
Technology Administrators
