Arnold for Cinema 4D Forum
Rendering with Arnold in CINEMA 4D using the C4DtoA plug-in.
C4D Arnold HDRI/Ground Plane Reflection issue
3 REPLIES 3
minidaz
573 Views, 3 Replies
Hello all,
Hope everyone is well? I have a question around ground plane reflection with Arnold and C4D. No matter what options I try I cannot seem to get the correct perspective around ground plane projection reflection. I have looked high and low and so far only found Maya workarounds.
So far I have tried setting up a Ray-Switch network identical to the Maya 2020 solution. Turned on and off shadows in the Tag parameter options for the Shadow-Matte (with and without Ray-Switch Network) which resulted in weird anomalies (pic 2 and 3), despite that often mentioned in posts/tutorials as the go to solution. It appears the only way I can get close is with the Ray-Switch which Arnold for C4D appears to be missing a 'perspective type' option in the projection node? (See Ray-Switch Shader below).
Any help would be appreciated!
Close but no cigar!
Incorrect perspective reflection? (Using Ray-Switch with Spherical type) No 'Perspective type' option available?
Settings:
Tag Parameter shadow option set to 'on', Correct ground plane reflection but black area shows.
Tag parameter shadow option set to 'off' HDRI and ground-plan competing against each other.
Ray-Switch Shader Tree:
I designed 2 test options with 1x being an RGBA Projection, The second a Camera Projection shader. Both identical render results in (top pic).
Labels (2)
3 REPLIES 3
lee_griggs
in reply to: minidaz
Have you tried offscreen_color?
Lee Griggs
Arnold rendering specialist
AUTODESK
minidaz
Hello Lee,
Thanks for your feedback! I tried the suggestion from the Arnold but unfortunately I have ended up with another issue in the process. When I apply the background image to the either the Offscreen Colour Link or Offscreen Colour slot it seems to solve the issue but I end up with a sharp edge of the ShadowMatte Plane that is not matched to the HDRI (Circled in red) and a secondary image of the background image (circled in blue)? So in reality I have 3 reflected images on the chrome sphere. 1x HDRI, 1x Ground Plane, 1x Ground Plane in Offsrceen slot?
Is their a way to feather the edge of the ground plane reflection? Or am I looking at this the wrong way?
6893-shadow-matte.jpgCheers
Darren
systembolaget
Can't you map the ground plane with a transparency/opacity map to feather it out?
