Arnold for Cinema 4D Forum
Rendering with Arnold in CINEMA 4D using the C4DtoA plug-in.
Bump outpout c4dto?
6 REPLIES 6
nezgro79
182 Views, 6 Replies
Bump outpout c4dto?
hello ! where i connect the oupout of my bump node i dont understand ?
6 REPLIES 6
in reply to: nezgro79
normal map Output==> Bump2D Normal
Bump2D Output ==> Standard Surface Normal
nezgro79
ok but if i have a normal map and a bump map i can connect one node to the standar surface normal ?
You have to combine first normal map and bump map together like I told you in my preview post, then connect the last node to Standard Surface Normal
nezgro79
like this ?
like this one
nezgro79
yes thank you 😉
