Arnold for Cinema 4D Forum
Rendering with Arnold in CINEMA 4D using the C4DtoA plug-in.
Bug with Rendervisibility & Layers
3 REPLIES 3
321 Views, 3 Replies
Hi guys,
when using Layers inside C4D and deactivating a layer for rendering Arnold does not properly interpret the order in which the rendervisibility is determined. Because you can simply overrwrite the layer setting with turning both renderflags for the object to on.
I attached a small testscene - Standard render doesnt render the object, Arnold does.
renderlayer.zip
Can anyone confirm?
Thanks!
Tags (2)
Labels (2)
3 REPLIES 3
peter.horvath6V6K3
Yeah, it definitely seems like a bug. I will fix this in the next release. Thanks for reporting.
peter.horvath6V6K3
The fix is available in the latest 2.2.3 release.
Amazing as always! Thank you 🙂
Technology Administrators
