[BUG] user_data_rgb in new C4D node editor is missing the Attribute field
jdm_007
jdm_007
When adding a user_data_rgb to the new C4D node editor, the attribute field is missing. Only the default color value is showing up.
The expresso node editor shows the attribute correctly and user_data_rgba also shows the attribute field correctly in both the old and new node editor.
peter_horvath
Can you tell me your C4DtoA and Cinema 4D version? I've tried the latest release (C4DtoA 4.5.1) in cinema 4D 2023 and it was showing the Attribute field properly.
// Peter Horvath
// C4DtoA developer
jdm_007
I am using C4D 2023.1.3 with Arnold 4.5.1 on MacOS.
peter_horvath
Indeed, the attribute is missing in Cinema 4D 2023.1.3. Something must have changed, I'll try to fix this in the next release.
// Peter Horvath
// C4DtoA developer
peter_horvath
This is now fixed in C4DtoA 4.5.1.1. Thanks again for reporting the issue.
// Peter Horvath
// C4DtoA developer
