Arnold for Cinema 4D Forum
Rendering with Arnold in CINEMA 4D using the C4DtoA plug-in.
Best method to see textures in viewport
10 REPLIES 10
Message 1 of 11
edenexposito
3628 Views, 10 Replies
To see a texture in viewport from a object with Arnold shader I need to create a standard C4D material and assign it temporarly... Maybe exists a better method to avoid this process, someone know a better solution?
Tags (1)
Labels (1)
10 REPLIES 10
Message 2 of 11
There is an Arnold Viewport slot in the shader network editor. Connecting an image shader or a standard_surface shader should appear in the viewport.
It's a bit slower than the C4D material though, unfortunately the SDK is limited and I could not find a better way so far.
Message 3 of 11
edenexposito
in reply to: edenexposito
Thanks! too easy!
Message 4 of 11
follow up question: how do I make transparent textures (textures with transmission) appear in the viewport?
Message 5 of 11
peter.horvath6V6K3
Unfortunately viewport display of the Arnold shaders are currently very limited and transparency or transmission is not supported.
Message 6 of 11
This only works 20% of the time for me
Message 7 of 11
peter.horvath6V6K3
Do you see red textures in the viewport, when it does not work? Or just nothing appears?
Message 8 of 11
in reply to: peter.horvath6V6K3
Yes! Red in the viewport. Plus I don't know how to make them high-res in the viewport. They are always quite low.
Message 9 of 11
I may have a fix for that coming in the next release. I also hope that I can improve the implementation a bit for simple cases.
You can change the resolution via the Texture preview size parameter of the Arnold Material.
Message 10 of 11
I see - its in the material tab. Works perfectly. That's bugged me for age I must ask more questions on here!
Message 11 of 11
Optichiasm
@Peter Horvath thank u! best solution for me.
