Arnold for Cinema 4D Forum
Rendering with Arnold in CINEMA 4D using the C4DtoA plug-in.
bake curvature map
3 REPLIES 3
thomas4K5GA
148 Views, 3 Replies
bake curvature map
I am unable to bake a curvature shader map. see attached screenshots.
- its not inside a cloner or another geometry.
- the mesh has UVs
- the only shader is a curvature node
3 REPLIES 3
peter_horvath
in reply to: thomas4K5GA
I tested curvature with a simple geo and that was working fine.
Maybe try a different (higher or lower) Surface Offset. See if that makes any difference.
You can also try to bake another shader, to verify if the issue is related to curvature or something more generic.
// Peter Horvath
// C4DtoA developer
thomas4K5GA
thank you I'll try
thomas4K5GA
mu uvs weren't quite right. solved
Technology Administrators
