Specifically the legacy blinders asset, i have added a scene with it here as a zip.
Pressing render to picture viewer works normally with no crash, but using IPR renders for a couple of seconds, then it acts a bit weird and freezes one second then it crashes.
Selecting all of the blinders content and making them editable solves it so im guessing its one of the c4d generators doing it. I checked the 3 cloners but its not them doing it. Bunch of other generators there, some probably outdated cause its an older asset.
I'm not able to reproduce it. The scene renders fine in the Picture Viewer and also in IPR. What's your Cinema 4D and C4DtoA version? If you are on windows, are you rendering on the CPU or GPU?
Also on windows there's usually a minidump file in the bugreport folder if there's a crash. Would you mind sending it to me if it exists? The folder is under the preferences folder usually in c:\Users\[your_user]\AppData\Roaming\MAXON\Maxon Cinema 4D 2024_9A37B6BA\_bugreports. (You can check the exact folder at the bottom of the Cinema 4D Preferences dialog.)
Should be latest C4D and latest C4dtoA. It happens on cpu and its also a hard crash so i dont think it makes a dump, i will double check again tomorrow.
Not a biggie for me since its an old asset from the legacy models in c4d, was mostly just going to use it as a gobo.
It did give a crash dump.
Latest C4D and c4dtoa, and happens the same with GPU ipr
