Arnold volume does not recognize grids
honorsforgod
Message 1 of 16
honorsforgod
Arnold volume does not recognize grids but c4d native VDB volume works fine
Replies (15)
Message 2 of 16
peter.horvath6V6K3
Maybe it's an OpenVDB version issue. Can you send us a VDB file to check?
Message 3 of 16
honorsforgod
Message 4 of 16
honorsforgod
[c4dtoa] 00:00:01 5532MB WARNING | /Fire/Arnold_Volume.grids: use type ARRAY, not POINTER
[c4dtoa] 00:00:01 5532MB WARNING | /Fire/Arnold_Volume: could not set POINTER parameter "grids"
Message 5 of 16
honorsforgod
it's even caused the crash [GPU], when i delete the volume from my scene everything works fine
Message 6 of 16
madsd
So, this works fine in MaxToA.
I can call the 3 channels, flames, temperature, density which are visible in the VDB.
I can call them through OSL 3dtexture(); call and by just injecting the string names to the Arnold volume material.
Message 7 of 16
lee_griggs
Lee Griggs
Arnold rendering specialist
AUTODESK
Message 8 of 16
honorsforgod
yeah correct that's it, so odd
now I am able to load it
Message 9 of 16
honorsforgod
when i use Gpu i crash
Message 10 of 16
honorsforgod
Message 11 of 16
honorsforgod
[c4dtoa] 00:00:53 3454MB WARNING | [imagers] forcing box filter due to usage of OptiX/OIDN imager
[c4dtoa] 00:02:26 7430MB ERROR | [gpu] an error happened during rendering. OptiX error is: Unknown error (Details: Function "_rtContextLaunch2D" caught exception: Encountered a CUDA error: cudaDriver().CuEventSynchronize( m_event ) returned (700): Illegal address, file: <internal>, line: 0)
GPU 0 had 10136MB free before rendering started and 4620MB free when crash occurred
Message 12 of 16
honorsforgod
my scene: atmospher_Volume and VDB volume[fire] and mesh light for rear lights of the car
when I delete the fire ---> GPU OK
when I delete the car and keep the fire only ---> GPU OK
everything in the scene ---> GPU Crash
Message 13 of 16
peter.horvath6V6K3
I can not reproduce the crash. The vdb and the grids are loaded and rendered fine on CPU and GPU. Make sure you are using the latest C4DtoA 4.0.3.2. From the log it seems the Optix denoiser is enabled. What if you try without that?
Message 14 of 16
honorsforgod
I disabled denoiser still keep crashing, yeah I using the latest one C4DtoA 4.0.3.2
Message 15 of 16
peter.horvath6V6K3
Any chance you can send us the scene? You can send it to support(at)arnoldrenderer(dot)com
Message 16 of 16
honorsforgod
it's not a simple scene to compact and send. it has a lot of material with external texture and large VDB files and Alembic involved too
