Arnold for Cinema 4D Forum
Rendering with Arnold in CINEMA 4D using the C4DtoA plug-in.
arnold transparent logo
12 REPLIES 12
Message 1 of 13
pleiada
797 Views, 12 Replies
I am trying to put logo on the basketball, and created set selection area for it, but it doesn't work properly. Following youtube instruction doesn't work. 6675-screen-shot-2020-04-14-at-123251-pm.png
https://drive.google.com/open?id=18kMs-DR6JzDFu3aZOSdADNzK5f655Out
c4d file with textures is linked
Tags (1)
Labels (1)
12 REPLIES 12
Message 2 of 13
lee_griggs
in reply to: pleiada
You can quite easily achieve this effect using Arnold's layer shaders or mix between two standard_surface shaders.
Lee Griggs
Arnold rendering specialist
AUTODESK
Message 3 of 13
I've found two problems:
  • The plugin does not handle stacking with multiple UVW tags properly. To fix this, I renamed the second UVW tag to 'UVW2' and changed the Bitmap shaders to image shaders, where the custom UV set can be defined (UV coordinates tab). Hope I can fix this in the plugin, so this manual workaround won't be necessary.
  • For some reason the common area of the 'orange' and 'logo' polygon selections are not recognized. Maybe it's an issue with the mesh or the selections, I'm not sure. What I did is to add the orange material to the entire mesh as well, as the base layer.
Message 4 of 13
I did the same, but it still doesn't work.. https://drive.google.com/drive/folders/1KjPvryrq9od5mDP0eWTXmT2FVH7Y1y_i?usp=sharing but sounds reasonable)
Message 5 of 13
pleiada
in reply to: lee_griggs
i know, but it doesn't work in this case.
Message 6 of 13
lee_griggs
Why don't they work?
Lee Griggs
AUTODESK
Message 7 of 13
Ahh, sorry, I forgot to send you the scene with the modifications. Here it is:
basketball_good_v02.zip
The key is to specify the UV set in the image shaders, like this:
Message 8 of 13
thank you for your help!
Message 9 of 13
I am having same problem again with another object. Maybe you can take a look why the alpha doesn't work? I tried changing UVW set and assign alpha as shader and texture. https://drive.google.com/drive/folders/1ONTKw2xRZsmK2VH5gZAOYDTk4Ru8pDjp?usp=sharing
Message 10 of 13
I attached a modified scene. You have two options:
  • Alpha stacking (see Plane😞 add a base material with no alpha and your butterfly material with the alpha texture in the Alpha channel.
  • Mix shader (see Plane.1😞 add a mix shader with the base butterfly layers driven by the alpha texture.
Hope this helps.
Message 11 of 13
I opened your file, but it still shows green polygon. https://drive.google.com/drive/folders/1t9YhZhPoPGbyopb1eyXhu5YOZoHb9_ac?usp=sharing7381-screen-shot-2020-06-16-at-12710-pm.png
Message 12 of 13
Yes, I set green color in the base layer. If you want to make it transparent, then set the Geometry > Cutout opacity parameter of the standard_surface shader.
Message 13 of 13
Cool! Didn't know this feature. Thank you!
