Arnold render hair doesn't match the C4D standard render
Brian_Re
Brian_Re
I need some help please !
So I added hair to a mesh and controlled its length curls twist ... in the standart c4d hair material and for the color and spec i used arnold standard hair . However when i render in arnold i dont ge the result i want . The main problem comes from the lengh parametre in the native hair material . Somehow arnold does not work well with it . Because when i disable it the hair kinda render properly but i dont get the length falloff i'm aiming for .
I just want the same result i get in the standard render to be in the arnold render !
I hope it makes sense !
peter_horvath
There are some use-cases where the default hair generation method can not replicate the native result. Add an Arnold tag to the Hair object and enable Render via Hair Render effect under the Advanced tab. Does that match the Standard render?
https://help.autodesk.com/view/ARNOL/ENU/?guid=arnold_for_cinema_4d_ci_Shapes_ci_Hair_object_html
Note, that this option has some limitations. It might not render correctly in the IPR and does not support motion blur.
// Peter Horvath
// C4DtoA developer
Brian_Re
I tried it, but the problem remains.
Brian_Re
I discovered a solution. It has something to do with the UV space.Because the mesh UV is in UDIMS, when the UV is in the (1002, 1004,1006,1008) space, it does not work, but it works when it is on 1001.1003.1005. It may appear confusing, but this is what worked for me.
