Arnold for Cinema 4D Forum
Rendering with Arnold in CINEMA 4D using the C4DtoA plug-in.
Arnold procedural and user_data_rgb
1 REPLY 1
tnurgmai
196 Views, 1 Reply
I'm using a cloner to clone several objects, and I'm using the Fields Color of the Plain Effector. I apply an Arnold shader using user_data_rgb and select Display Color (Mograph Shader) and apply it to the cloner. The Arnold shader is correctly reading the colors from the Mograph Shader. Next, I want to replace the objects using Arnold procedurals and I use .ass files. The problem is that the Arnold shader does not seem to work with the procedural. The color of all the objects are black.
Tags (1)
Labels (1)
1 REPLY 1
If you export an object to an ASS file, its display color is set to black. The procedural does not override it in this case. What you can do as a workaround, is to open the .ass file with a text editor and remove the lines
 declare display_color constant RGB
 display_color 0 0 0
from the polymesh. Then the display_color defined on the procedural should be used in the render.
