Arnold for Cinema 4D Forum
Rendering with Arnold in CINEMA 4D using the C4DtoA plug-in.
Arnold Object Masks -> PSD selections
1 REPLY 1
jrodney55
164 Views, 1 Reply
With C4D Physical render engine, I'm used to setting up Object Buffers and outputting as PSD, and then the PSD file has selections for each buffer in the Select -> Load Selection... window dropdown list. I can simply choose the selection I want - very quick & easy. I've been trying to get this same result using Arnold Object Masks, but no luck. Is this doable in Arnold?screen-shot-2020-12-17-at-120349-pm.jpg
Tags (1)
Labels (1)
1 REPLY 1
Those Object Buffers are a special type buffers which are currently not supported by C4DtoA. I have to check if they can be created via the C4D SDK, I'm not sure. I think there's no better option at the moment than the Arnold Object Mask.
