Arnold for Cinema 4D Forum
Rendering with Arnold in CINEMA 4D using the C4DtoA plug-in.
arnold mesh tag to multiple objects
6 REPLIES 6
391 Views, 6 Replies
Hi I want to apply a mesh light to multiple bulbs in different groups but cant find a quick solution to it? Does anyone know an efficient way?
Thanks!
Tags (2)
Labels (2)
6 REPLIES 6
Jo_Griffin
Heh funny, I'm working on something very similar. (see my post just now).
Use the Meshlight Tag instead of the object. Then you can clone the lightbulb along a spline. I also managed to get the lights to flicker on/off using a Mograph effector.
in reply to: Jo_Griffin
Oh great thanks!
peter.horvath6V6K3
Using the Arnold Mesh Light tag is recommended. Then you can just select multiple objects and assign the tag to them like any other tags. And you can also clone the object with the tag as Jo suggested.
in reply to: peter.horvath6V6K3
Hi Thanks for the answer,
I was wondering if I could something like this (see image) but it doesn't work. I don't want to manually go through each capsule. I, unfortunately, made the cloner that I used to align each bulb so I don't want to recreate that again. assigning-one-mesh-light-to-multiple-object.jpg
peter.horvath6V6K3
Unfortunately the mesh light tag is not hierarchical, so it does not work when assigned to a parent object.
If all your objects called Capsule you can filter by name in the object editor, select all and add the tag to them in one step.
great thank you!!
