Arnold for Cinema 4D Forum
Rendering with Arnold in CINEMA 4D using the C4DtoA plug-in.
Arnold denoiser only works with default filter gaussian? [c4dtoa]
2 REPLIES 2
meK6ADE
242 Views, 2 Replies
Hi, beginner here trying to understand the denoiser workflow.
I've gotten so far that I understand that we have denoising as a post process effect via the Arnold Imager not suited for animations. Then we have the Arnold Denoiser that works on rendered .exr images with a specific AOV, and this do work with animation.
I tried running the Denoiser several times without any result, the new image sequence was exactly the same as the input. Then I tried changing the default filter to gaussian from box and all of a sudden it worked. Why is this? What is happening here? What am I not understanding in how gaussian calculates the sub-pixels that makes it required for denoising?
Anyone care to explain this process?
Tags (1)
Labels (1)
2 REPLIES 2
Stephen.Blair
in reply to: meK6ADE
The beauty has to use the same filter as the other denoiser AOVs (N, Z, variance, denoise_albedo). Those AOVs are created by C4DtoA for you, and they use the gaussian filter.
// Stephen Blair
// Arnold Renderer Support
meK6ADE
Thanks Stephen.
This info should be added to the documentation, hard to figure this out through the help docs.
