Arnold for Cinema 4D Forum
Rendering with Arnold in CINEMA 4D using the C4DtoA plug-in.
Arnold Denoiser AOV
2 REPLIES 2
Prince_Ude
301 Views, 2 Replies
Arnold Denoiser AOV
Hi, I was wondering if anyone had any idea on how to use the C4DtoA Arnold Denoiser output AOV in a compositing app like Fusion?.
After applying the denoiser, it exports a denoised beauty layer which overshadows other aov passes.
I’d appreciate a lot if i could get a workflow walkthrough regarding this issue.
Tags (3)
Labels (3)
2 REPLIES 2
Stephen.Blair
in reply to: Prince_Ude
Apply the denoiser to the other AOVs?
Or work with the non-denoised beauty.
// Stephen Blair
// Arnold Renderer Support
Prince_Ude
The beauty layer is made up of different AOVs, adding and using the denoised beauty layer in compositing will prevent me from working separately on other AOVs. So, is there a workflow that allows me to extract the denoise data and use it as another AOV pass in a compositing app like Fusion?. Is it possible to have the denoise data on a seperate AOV pass (like SSS, Diffuse direct, Specular Indirect)... rather than a denoised beauty layer.
