Arnold can't be installed C4D 2023 on Apple M2
polta.co
polta.co
Hi there,
I read that some users installed Arnold on a Apple Silicon successfully.
The installer works on my side, but without pointing to the C4D 2023 directory during Installation, Arnold is installed into a new directory C4D R26 next to my C4D 2023.
When I launch C4D 2023 Arnold doesn't show up.
I've installed Rosetta. I also set permissions on the plugin folder to full access with no luck.
Do I need to setup something else to make this work?
Do I miss something?
Thanks guys!
Mac Studio M2 Ultra
OS: Ventura 13.5 (latest)
C4D 2023.2.2 (latest)
Arnold 4.6.4.1
peter_horvath
First of all, make sure you have downloaded the right installer: C4DtoA-4.6.4.1-darwin-2023.pkg
Then make sure you selected the right folder, where your Cinema 4D is installed, as described here in step 4: https://help.autodesk.com/view/ARNOL/ENU/?guid=arnold_for_cinema_4d_ci_Installation_ci_Installing_Ar...
// Peter Horvath
// C4DtoA developer
polta.co
Hi Peter,
thanks for helping out. My bad!  I was using the wrong installer.
In the download section the versions are ordered in an ascending order, but 2023 is on the first place and I downloaded the R26 version.
Sorry for bothering you.
Thanks.
Best Regards
Everything works perfect!
