Arnold for Cinema 4D Forum
Rendering with Arnold in CINEMA 4D using the C4DtoA plug-in.
Arnold and C4D - hair work in IPR but not in final render
4 REPLIES 4
giorgioelv
268 Views, 4 Replies
i have a problem, maybe because I'm new to Arnold render.
Just test some hair material and everything works in IPR window, but when i try to do a final render in Cinema 4D, it's like my hair do not have material or pose, just straight hair.
How can i fix this? What tag i just forgot?
Tags (1)
Labels (1)
4 REPLIES 4
in reply to: giorgioelv
Upload a scene file
giorgioelv
Hi, thank you for the answer.
Maybe can be a scene problem, because today I was making the scene to upload, but work normally... I'll do some testing later
Thank you anyway!
Regards
Ok no problem
Hard to say without seeing the scene. Ideally the IPR and final render should look the same, although they use different inputs. C4D adds an extra step when doing a final render which converts the viewport scene to a render scene. If you have the same (wrong) result with the Standard Renderer, then it may be a C4D issue. Otherwise it could be a bug or misuse in Arnold/C4DtoA. In this case please send me the scene if possible, so I can take a look.
