Arnold for Cinema 4D Forum
Rendering with Arnold in CINEMA 4D using the C4DtoA plug-in.
Arnold 6 VDB not working
2 REPLIES 2
asam.motion
747 Views, 2 Replies
Hello
I am using C4D R20 and R21 with Arnold 6.0.2.1
When ever I load and Open vdb it does not show up, does not populate the Available grids section or display a volume container.
I was working with the same Open vdb files earlier this week with c4d to A Arnold 5.? and everything was fine.
The vdb files I am using are from THE PIXEL LAB VDB Smoke Pack and VDB Cloud Pack
When I load any other vdp from https://www.openvdb.org/ they work fine. The Available grids show up like they always have.
When I load THE PIXEL LAB open vdb. I see nothing in the available grids section
Do you know if this is a problem with Arnold 6.0.2.1 only.
I would appreciate any help with this
Thank you
A
Tags (1)
Labels (1)
  • vdb
2 REPLIES 2
lee_griggs
in reply to: asam.motion
Can you find out which grids the VDB volumes were saved with? density?
Lee Griggs
Arnold rendering specialist
AUTODESK
Here's the quick fix. After loading the path into the Arnold Volume, change the last four digits to hash marks: Example: Pixel-Lab-VDB/smoke_041_High_Res/smoke_041_0.07_####.vdb
