Arnold 6 C4D _ Ramp RGB_multi image does not work
Hakan_Taner_Esse
Hakan_Taner_Esse
Hello RGB color ramp does not work. İmages are combined with each other. How can ı seperate images? I would like to arrange cubes which represent different images.
Stephen.Blair
Why not use a switch instead?
What is the user data? An int?
A ramp worked for me when I tested it in Maya. Didn't try in CINEMA 4D yet, but it's the same Arnold shaders.
// Stephen Blair
// Arnold Renderer Support
Stephen.Blair
User data should be a float, if you're using a ramp between 0 and 1.
I wouldn't use RGB user data.
// Stephen Blair
