12:32 PM
Hi there,
I have a bunch of AOVs/ Masks that I want to render out. I have set the display driver's type to driver_tiff, I have the Merge option off and the filter on default gaussian. When I hit render, the output consists of 8 different AOV renders that all look completely alike (I think it is only the contour alpha that is being rendered; I am using the contour shader). Although in the IPR window everything looks correct (with the display driver's type set to driver_display).
What could be the cause of this? There is a "render AOV" checkbox in the render settings>AOVs checkbox that is greyed out for every AOV except for beauty, could that be the reason?
Thank you and best regards
