Arnold for Cinema 4D Forum
Rendering with Arnold in CINEMA 4D using the C4DtoA plug-in.
Anyway to render DOF pass with objects in scene that have Transmission?
3 REPLIES 3
239 Views, 3 Replies
I have a scene with several 'thin' glass discs. DOF works fine when rendering straight out from the render but if i render with a Zpass to composite DOF in AE it doesn't read the 'transmission' (glass discs), they are just solid. I want to save render times by not having to render the scene with DOF and using a Zpass in AE will help with that. Is there any work around to get it to work correctly?
Tags (2)
Labels (2)
3 REPLIES 3
lee_griggs
Have you tried Transmit AOVs?
Lee Griggs
Arnold rendering specialist
AUTODESK
in reply to: lee_griggs
Hi. I haven't tried that option yet but will give it a go.
Hi Lee
I have just tried the Transmit AOVs but the Zpass isn't working as i hoped. Have attached a screenshot from AE (the discs are the glass discs). Do you know if there's anything else i needed to do apart from checking the Transmit AOVs and using the Zpass AOV?6021-screen-shot-2020-02-24-at-090315.png
