Arnold for Cinema 4D Forum
Rendering with Arnold in CINEMA 4D using the C4DtoA plug-in.
Animated texture correct in IPR but error to render
7 REPLIES 7
Message 1 of 8
edenexposito
301 Views, 7 Replies
I have added an animated sequence of tx textures through "bitmap" node and work's perfectly when I see it through IPR, but when I try to render it I get a texture error and render abort.
Tags (1)
Labels (1)
7 REPLIES 7
Message 2 of 8
What's your setting in the Bitmap shader? Maybe it starts at frame 0 but your file sequence starts only from frame 1?
Message 3 of 8
edenexposito
in reply to: edenexposito
from 0 to 50.
I test with exr and tx... both with problem when render.
Message 4 of 8
The setup looks good. And the error in the log says it does not find the file?
Message 5 of 8
edenexposito
Yes, seems that It can not find files when render, but in IPR I see all sequence correctly, very strange. Seems a bug.
Message 6 of 8
I'm not able to reproduce it. Can you show me the error of this particular scene?
Message 7 of 8
edenexposito
Sorry, you are right, was my fault. Due to start frame in 0 instead 1. I'm linking to wrong sequence...
Sorry again.
Message 8 of 8
OK, I'm glad you found the problem (and it's not a bug in the plugin eventually).
