Arnold for Cinema 4D Forum
Rendering with Arnold in CINEMA 4D using the C4DtoA plug-in.
Animated atmosphere volume movement with noise?
2 REPLIES 2
f.ribbeck
603 Views, 2 Replies
I am currently trying to create an atmosphere volume that has some movement to it, fog movement like you would expect in a sauna for example or from a hot water pool, where the mist gets twirled around a bit and is patchy. I am trying to create this effect with different noise and displacement approaches inside the atmosphere volume, but so far without success. Is this even possible with the atmosphere volume or should I use a normal Arnold volume instead? Did anybody manage to do something similar?
Thanks and best regards!
Labels (4)
2 REPLIES 2
diego6S3FN
in reply to: f.ribbeck
Hi, I did this a while ago and it rendered very fast, I think I connected a C4d Noise to the atmosphere_volume node Density. But you have to move black and with noise values near the white both or something like that, the best thing is to put a color_correct to the noise and play with the contrast and exposure or gamma.
Also the noise scale will have to be played with to find something that is visible,
Cheers
Diego
f.ribbeck
Hi Diego, thank you very much for your answer! I will try it out this way. I did use a C4D noise, but I just didn't see any difference, probably because of the parameters you described where not set correctly
