Arnold for Cinema 4D Forum
Rendering with Arnold in CINEMA 4D using the C4DtoA plug-in.
alpha(stacking) node may be have some bugs
1 REPLY 1
86 Views, 1 Reply
For example, I have a torus,Add a blue material to the torus,and I pasted a circle of purple material on some surfaces of the torus,and then,Create a new material, connect the alpha (stacking) node with a map with an alpha channel, change projection to falt,paste the material into the torus,and open the IPR. It works perfectly.but if I adjust the purple material (any parameter) , IPR will display incorrectly.Please check the attached video,thanks
Incidentally, the ramp_rgb  node is also unavailable
1 REPLY 1
peter_horvath
in reply to: 895793442
Looks like a bug indeed. Is it just an IPR update issue? I mean, does it show the correct render if you restart the IPR or render to the Picture Viewer?
// Peter Horvath
// C4DtoA developer
