added bounds could be 1.99x more efficient?
gomeslindsay
gomeslindsay
what does this mean and how would I go about fixing it since I have them on multiple textures
"added bounds could be 1.99x more efficient. given disp_padding: 0.00300000003, recommended: 4.847534e-07"
peter.horvath6V6K3
See the Bounds Padding section in the displacement docs: https://docs.arnoldrenderer.com/display/A5AFCUG/Displacement+shaders#Displacementshaders-BoundsPaddi...
If padding is lower than the recommended, it can cause artifacts. However in your case it should be fine. If you want to get rid of the warning, you have to set the padding close to the recommended value. (Note, that the value in Arnold is probably in meters, while it's in cm on the UI.)
