Arnold for Cinema 4D Forum
Rendering with Arnold in CINEMA 4D using the C4DtoA plug-in.
Adaptive Sampling & AA_inv_density
2 REPLIES 2
lizGYM66
175 Views, 2 Replies
When previewing what the adaptive sampling via the AA_inv_density AOV, do you need to put in the minimum filter value in addition to the maximum ? Only seems to work when I put in the maximum filter value (same as max AA under adaptive sampling).
2 REPLIES 2
peter_horvath
in reply to: lizGYM66
I suppose you are using a heatmap filter to visualize the inv density. You don't need to change the minimum and maximum value of the filter to see the density, you can keep it on 0 to 1, as that's the range of the AOV. But if you want to give the heatmap a bigger spread of colors visually, you can change the range and use AA sample and max AA samples to maximize the color differences.
// Peter Horvath
// C4DtoA developer
lizGYM66
I'm not sure where I heard about adding the samples max to the aa_inv heat map, but leaving it at default works perfectly. Thanks for the clarification.
