Arnold for Cinema 4D Forum
Rendering with Arnold in CINEMA 4D using the C4DtoA plug-in.
3D Spherical Gradient Shader for Volume Density?
1 REPLY 1
astrofalcon
780 Views, 1 Reply
Does anyone know how to make the equivalent of Cinema 4Ds 3D-Spherical Gradient Shader? I'm trying to use this shader for the density of an Arnold Volume Sphere. I'm trying to avoid making custom VDBs to get the effect I need... Ultimately I'm trying to create an atmosphere falloff or fadeout but in XYZ 3D space not just UV that I can pipe into the density parameter of a volume shader.
Thanks so much!!!
- Shawn
Tags (2)
Labels (2)
1 REPLY 1
You need to control a ramp shader with the distance of the shading point. Try to build the following shader network: state_vector with Po -> length -> divide by the Sphere radius -> ramp_float.Input -> standard_volume.Density. Hope this helps.
