Arnold for Cinema 4D Forum
Rendering with Arnold in CINEMA 4D using the C4DtoA plug-in.
3D gradient
3 REPLIES 3
info
126 Views, 3 Replies
3D gradient
Hi, I have a simple array of cubes and I need to apply a ramp that makes the cubes in the center white and the outer cubes black but in a gradual way as if it was a 3D volumetric gradient.
I can't find the combination of nodes to do this. It would have to be done in object mapping mode so that it can be animated in space.
I've seen some post asking about this but I can't find the solution.
If someone can give me some hints that would be great.
Thanks in advance
Diego
3 REPLIES 3
peter_horvath
in reply to: info
Maybe something like this?
The state_vector is set to 'shading point in world space (P)'. I assume the Cubes are generated by a Cloner, so you can use an object node to output the Global Position of the Cloner. Otherwise this should be the center point in world space. Basically this graph takes the distance of the shading point from the center and maps it to a (0-1) range via the range shader as the input of the ramp.
// Peter Horvath
// C4DtoA developer
info
in reply to: peter_horvath
Hello Peter, thank you very much, this is exactly what I was looking for.
lee_griggs
in reply to: info
You could also map a ramp_rgb to a triplanar shader.
Lee Griggs
Arnold rendering specialist
AUTODESK
