Arnold for Maya Forum
Rendering with Arnold in Maya using the MtoA plug-in.
Opacity issue with low-poly grass cards
2 REPLIES 2
wentzjm
509 Views, 2 Replies
These are simple cards with a standard surface material. A single image is driving the base color and opacity (alpha channel from the image is driving the opacity).
I've included viewport screens here of the cards both with and without the texture, and then an IPR render that shows my problem--there are spots in the render of opaque black. This should be a simple fix but I'm not sure what to do. Increasing the transmission rays and transmission samples didn't have an effect.
Labels (3)
2 REPLIES 2
thiago.ize
in reply to: wentzjm
What happens if you increase the auto_transparency_depth in the global options?
wentzjm
in reply to: thiago.ize
Oh ok, that was very easy. So it seems that if I had a whole field of these with a low camera I would need an enormous amount of transparency rays.
