Arnold for 3ds Max
Rendering with Arnold in 3ds Max using the MaxtoA plug-in.
Arnold Volumes - animated VDB does not work on Network Rendering
1 REPLY 1
b_connor
108 Views, 1 Reply
Hi, I am hoping someone can shed some light on a issue we have network rendering animated VDB's using Arnold Volumes.
I have a basic scene setup using an animated VDB in an Arnold Volume. When we render the sequence on a single PC it renders the entire animated sequence no issues.
When I network render it on our render farm, using either Backburner or Deadline, it renders the first frame but will fail all others.
I can render animated image sequences on billboard geometry fine network rendering using Arnold so I suspect the issue is with the Arnold Volume? My scene and VDB sequence are located on a shared server drive that all slaves/workers can access.
I was hoping someone could tell me how I can get this to work or if this is not currently supported.
Thanks in advance.
1 REPLY 1
CiroCardoso3v
in reply to: b_connor
Something that could help understand what is happening is a log to see why the render is failing.
Lead Enviroment Artist @Axis Studios
Arnold Discord Server
Ciro Cardoso
